{"name":"Tree Diagram Maker Deutsch","description":"","url":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de","home":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de","gmt_offset":"0","timezone_string":"","page_for_posts":635,"page_on_front":10,"show_on_front":"page","namespaces":["oembed\/1.0","betterdocs\/v1","contentviews\/v1","custom-permalinks\/v1","featured-image-from-url\/v2","featured-image-from-url\/v1","msls\/v1","yoast\/v1","elementor-one\/v1","zipwp\/v1","hfe\/v1","wpraddons\/v1\/ajaxselect2","wpr-addons\/v1","wpraddons\/v1","elementskit\/v1\/ajaxselect2","astra\/v1","betterdocs","elementor\/v1\/documents","elementor\/v1","elementor-ai\/v1","elementor\/v1\/feedback","elementskit\/v1\/widget\/mailchimp","elementskit\/v1\/dynamic-content","elementskit\/v1\/layout-manager-api","elementskit\/v1\/my-template","elementskit\/v1\/megamenu","one-onboarding\/v1","getting-started\/v1","zipwp-images\/v1","nps-survey\/v1","gutenberg-templates\/v1","bsf-core\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Die URL der Ressource, f\u00fcr die oEmbed-Daten abgerufen werden sollen.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Die URL der Ressource, f\u00fcr die oEmbed-Daten abgerufen werden sollen.","type":"string","format":"uri","required":true},"format":{"description":"Das zu verwendende oEmbed-Format.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"Die maximale Breite des eingebundenen Frames in Pixeln.","type":"integer","default":600,"required":false},"maxheight":{"description":"Die maximale H\u00f6he des eingebundenen Frames in Pixeln.","type":"integer","required":false},"discover":{"description":"Ob eine oEmbed-Discovery-Anfrage f\u00fcr nicht autorisierte Anbieter durchgef\u00fchrt werden soll.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/oembed\/1.0\/proxy"}]}},"\/betterdocs\/v1":{"namespace":"betterdocs\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"betterdocs\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1"}]}},"\/betterdocs\/v1\/doc-categories":{"namespace":"betterdocs\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"password":{"description":"The password for password-protected docs.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/doc-categories"}]}},"\/betterdocs\/v1\/doc-categories-kb":{"namespace":"betterdocs\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/doc-categories-kb"}]}},"\/betterdocs\/v1\/search":{"namespace":"betterdocs\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"password":{"description":"The password for password-protected docs.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/search"}]}},"\/betterdocs\/v1\/search-insert":{"namespace":"betterdocs\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/search-insert"}]}},"\/betterdocs\/v1\/get-terms":{"namespace":"betterdocs\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/get-terms"}]}},"\/betterdocs\/v1\/months-with-posts":{"namespace":"betterdocs\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/months-with-posts"}]}},"\/betterdocs\/v1\/order_docs":{"namespace":"betterdocs\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"password":{"description":"The password for password-protected docs.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/order_docs"}]}},"\/betterdocs\/v1\/docs-faq-count":{"namespace":"betterdocs\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/docs-faq-count"}]}},"\/betterdocs\/v1\/faq-terms-by-keyword-search":{"namespace":"betterdocs\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"password":{"description":"The password for password-protected FAQs.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/faq-terms-by-keyword-search"}]}},"\/betterdocs\/v1\/faq-accordion-toggle":{"namespace":"betterdocs\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/faq-accordion-toggle"}]}},"\/betterdocs\/v1\/feedback\/(?P<id>\\d+)":{"namespace":"betterdocs\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"type":"integer","default":null,"required":false},"feelings":{"type":"string","required":true}}}]},"\/betterdocs\/v1\/settings":{"namespace":"betterdocs\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/settings"}]}},"\/betterdocs\/v1\/dark-mode":{"namespace":"betterdocs\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/dark-mode"}]}},"\/betterdocs\/v1\/plugin_insights":{"namespace":"betterdocs\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/plugin_insights"}]}},"\/betterdocs\/v1\/create-sample-docs":{"namespace":"betterdocs\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/create-sample-docs"}]}},"\/betterdocs\/v1\/reporting-test":{"namespace":"betterdocs\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/reporting-test"}]}},"\/betterdocs\/v1\/export-docs":{"namespace":"betterdocs\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/export-docs"}]}},"\/betterdocs\/v1\/export-settings":{"namespace":"betterdocs\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/export-settings"}]}},"\/betterdocs\/v1\/import-docs":{"namespace":"betterdocs\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/import-docs"}]}},"\/betterdocs\/v1\/import-settings":{"namespace":"betterdocs\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/import-settings"}]}},"\/betterdocs\/v1\/parse-xml":{"namespace":"betterdocs\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/parse-xml"}]}},"\/betterdocs\/v1\/parse-csv":{"namespace":"betterdocs\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/parse-csv"}]}},"\/betterdocs\/v1\/migrate":{"namespace":"betterdocs\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/migrate"}]}},"\/betterdocs\/v1\/helpscout-migration":{"namespace":"betterdocs\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/helpscout-migration"}]}},"\/betterdocs\/v1\/dashboard-mode":{"namespace":"betterdocs\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/v1\/dashboard-mode"}]}},"\/contentviews\/v1":{"namespace":"contentviews\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"contentviews\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/contentviews\/v1"}]}},"\/contentviews\/v1\/block_template_pattern":{"namespace":"contentviews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/contentviews\/v1\/block_template_pattern"}]}},"\/contentviews\/v1\/update_block_template_pattern":{"namespace":"contentviews\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/contentviews\/v1\/update_block_template_pattern"}]}},"\/custom-permalinks\/v1":{"namespace":"custom-permalinks\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"custom-permalinks\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/custom-permalinks\/v1"}]}},"\/custom-permalinks\/v1\/get-permalink\/(?P<id>\\d+)":{"namespace":"custom-permalinks\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false}}}]},"\/featured-image-from-url\/v2":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"featured-image-from-url\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2"}]}},"\/featured-image-from-url\/v2\/metadata_counter_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/metadata_counter_api"}]}},"\/featured-image-from-url\/v2\/enable_fake_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/enable_fake_api"}]}},"\/featured-image-from-url\/v2\/disable_fake_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/disable_fake_api"}]}},"\/featured-image-from-url\/v2\/data_clean_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/data_clean_api"}]}},"\/featured-image-from-url\/v2\/run_delete_all_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/run_delete_all_api"}]}},"\/featured-image-from-url\/v2\/disable_default_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/disable_default_api"}]}},"\/featured-image-from-url\/v2\/none_default_api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/none_default_api"}]}},"\/featured-image-from-url\/v2\/load-sizes-api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/load-sizes-api"}]}},"\/featured-image-from-url\/v2\/reset-sizes-api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/reset-sizes-api"}]}},"\/featured-image-from-url\/v2\/save-sizes-api":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/save-sizes-api"}]}},"\/featured-image-from-url\/v2\/pre_deactivate":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/pre_deactivate"}]}},"\/featured-image-from-url\/v2\/feedback":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/feedback"}]}},"\/featured-image-from-url\/v2\/deactivate_itself":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/deactivate_itself"}]}},"\/featured-image-from-url\/v2\/rest_url_api":{"namespace":"featured-image-from-url\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/rest_url_api"}]}},"\/featured-image-from-url\/v2\/metain":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/metain"}]}},"\/featured-image-from-url\/v2\/metaout":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/metaout"}]}},"\/featured-image-from-url\/v1":{"namespace":"featured-image-from-url\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"featured-image-from-url\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v1"}]}},"\/featured-image-from-url\/v1\/url\/(?P<post_id>\\d+)":{"namespace":"featured-image-from-url\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/featured-image-from-url\/v2\/create_thumbnails_list":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/create_thumbnails_list"}]}},"\/featured-image-from-url\/v2\/sign_up":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/sign_up"}]}},"\/featured-image-from-url\/v2\/connected":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/connected"}]}},"\/featured-image-from-url\/v2\/reset_credentials":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/reset_credentials"}]}},"\/featured-image-from-url\/v2\/list_all_su":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/list_all_su"}]}},"\/featured-image-from-url\/v2\/list_all_fifu":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/list_all_fifu"}]}},"\/featured-image-from-url\/v2\/list_all_media_library":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/list_all_media_library"}]}},"\/featured-image-from-url\/v2\/list_daily_count":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/list_daily_count"}]}},"\/featured-image-from-url\/v2\/delete":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/delete"}]}},"\/featured-image-from-url\/v2\/cancel":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/cancel"}]}},"\/featured-image-from-url\/v2\/payment_info":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/payment_info"}]}},"\/featured-image-from-url\/v2\/cloud_upload_auto":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/cloud_upload_auto"}]}},"\/featured-image-from-url\/v2\/cloud_delete_auto":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/cloud_delete_auto"}]}},"\/featured-image-from-url\/v2\/cloud_hotlink":{"namespace":"featured-image-from-url\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/cloud_hotlink"}]}},"\/featured-image-from-url\/v2\/debug-slug\/(?P<slug>[a-z0-9-_]+)":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"required":true}}}]},"\/featured-image-from-url\/v2\/debug-postmeta\/(?P<post_id>\\d+)":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_id":{"required":true}}}]},"\/featured-image-from-url\/v2\/debug-posts\/(?P<id>\\d+)":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":true}}}]},"\/featured-image-from-url\/v2\/debug-metain":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/debug-metain"}]}},"\/featured-image-from-url\/v2\/debug-metaout":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/featured-image-from-url\/v2\/debug-metaout"}]}},"\/featured-image-from-url\/v2\/debug-log\/(?P<type>(cloud|plugin))":{"namespace":"featured-image-from-url\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"required":true},"lines":{"required":false}}}]},"\/msls\/v1":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"msls\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/msls\/v1"}]}},"\/msls\/v1\/duplicate-post":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"required":true},"target_locale":{"required":true},"_elementor_data":{"required":false},"_yoast_wpseo_title":{"required":false},"_yoast_wpseo_metadesc":{"required":false},"update_existing":{"default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/msls\/v1\/duplicate-post"}]}},"\/msls\/v1\/posts-without-translation\/(?P<target_locale>[a-zA-Z0-9_-]+)":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"target_locale":{"required":true},"post_type":{"default":"post","required":false}}}]},"\/msls\/v1\/posts-missing-translations":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"default":"publish","required":false},"post_type":{"default":"all","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/msls\/v1\/posts-missing-translations"}]}},"\/msls\/v1\/fix-taxonomies":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"source_post_id":{"required":true},"source_blog_id":{"required":true},"target_post_id":{"required":true},"target_blog_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/msls\/v1\/fix-taxonomies"}]}},"\/msls\/v1\/fix-all-taxonomies":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"dry_run":{"default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/msls\/v1\/fix-all-taxonomies"}]}},"\/msls\/v1\/fix-post-parents":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"dry_run":{"default":true,"required":false},"source_blog_id":{"default":1,"required":false},"verbose":{"default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/msls\/v1\/fix-post-parents"}]}},"\/msls\/v1\/fix-post-dates":{"namespace":"msls\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"dry_run":{"default":true,"required":false},"source_blog_id":{"default":1,"required":false},"limit":{"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/msls\/v1\/fix-post-dates"}]}},"\/msls\/v1\/outdated-translations":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_type":{"default":"all","required":false},"status":{"default":"publish","required":false},"languages":{"default":"","required":false},"source_blog_id":{"default":1,"required":false},"limit":{"default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/msls\/v1\/outdated-translations"}]}},"\/msls\/v1\/blog-language-map":{"namespace":"msls\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/msls\/v1\/blog-language-map"}]}},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/ai_generator\/callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/ai_generator\/callback"}]}},"\/yoast\/v1\/ai_generator\/refresh_callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/ai_generator\/refresh_callback"}]}},"\/yoast\/v1\/ai_generator\/consent":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"consent":{"type":"boolean","description":"Whether the consent to use AI-based services has been given by the user.","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/ai_generator\/consent"}]}},"\/yoast\/v1\/ai\/free_sparks":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/ai\/free_sparks"}]}},"\/yoast\/v1\/ai_generator\/bust_subscription_cache":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/ai_generator\/bust_subscription_cache"}]}},"\/yoast\/v1\/ai_generator\/get_suggestions":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"type":"string","enum":["seo-title","meta-description","product-seo-title","product-meta-description","product-taxonomy-seo-title","product-taxonomy-meta-description","taxonomy-seo-title","taxonomy-meta-description"],"description":"The type of suggestion requested.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for suggestions.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":true},"language":{"type":"string","description":"The language the post is written in.","required":true},"platform":{"type":"string","enum":["Google","Facebook","Twitter"],"description":"The platform the post is intended for.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/ai_generator\/get_suggestions"}]}},"\/yoast\/v1\/ai_generator\/get_usage":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_woo_product_entity":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/ai_generator\/get_usage"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postTypeName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"taxonomyName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy"}]}},"\/yoast\/v1\/site_kit_configuration_permanent_dismissal":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_dismissed":{"type":"bool","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/site_kit_configuration_permanent_dismissal"}]}},"\/yoast\/v1\/readability_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/readability_scores"}]}},"\/yoast\/v1\/seo_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/seo_scores"}]}},"\/yoast\/v1\/setup_steps_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"setup_widget_loaded":{"type":"string","enum":["yes","no"],"required":false},"first_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"last_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"setup_widget_temporarily_dismissed":{"type":"string","enum":["yes","no"],"required":false},"setup_widget_permanently_dismissed":{"type":"string","enum":["yes","no"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/setup_steps_tracking"}]}},"\/yoast\/v1\/introductions\/(?P<introduction_id>[\\w-]+)\/seen":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"introduction_id":{"type":"string","required":true},"is_seen":{"type":"bool","default":true,"required":false}}}]},"\/yoast\/v1\/wistia_embed_permission":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"value":{"type":"bool","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/wistia_embed_permission"}]}},"\/yoast\/v1\/available_posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"type":"string","default":"","required":false},"postType":{"type":"string","default":"page","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/available_posts"}]}},"\/yoast\/v1\/alerts\/dismiss":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/alerts\/dismiss"}]}},"\/yoast\/v1\/configuration\/site_representation":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"company_or_person":{"type":"string","enum":["company","person"],"required":true},"company_name":{"type":"string","required":false},"company_logo":{"type":"string","required":false},"company_logo_id":{"type":"integer","required":false},"person_logo":{"type":"string","required":false},"person_logo_id":{"type":"integer","required":false},"company_or_person_user_id":{"type":"integer","required":false},"description":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/configuration\/site_representation"}]}},"\/yoast\/v1\/configuration\/social_profiles":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"facebook_site":{"type":"string","required":false},"twitter_site":{"type":"string","required":false},"other_social_urls":{"type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/configuration\/social_profiles"}]}},"\/yoast\/v1\/configuration\/check_capability":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/configuration\/check_capability"}]}},"\/yoast\/v1\/configuration\/enable_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"tracking":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/configuration\/enable_tracking"}]}},"\/yoast\/v1\/configuration\/save_configuration_state":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"finishedSteps":{"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/configuration\/save_configuration_state"}]}},"\/yoast\/v1\/configuration\/get_configuration_state":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/configuration\/get_configuration_state"}]}},"\/yoast\/v1\/import\/(?P<plugin>[\\w-]+)\/(?P<type>[\\w-]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/yoast\/v1\/get_head":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/get_head"}]}},"\/yoast\/v1\/indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/indexing\/posts"}]}},"\/yoast\/v1\/indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/indexing\/terms"}]}},"\/yoast\/v1\/indexing\/post-type-archives":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/indexing\/post-type-archives"}]}},"\/yoast\/v1\/indexing\/general":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/indexing\/general"}]}},"\/yoast\/v1\/indexing\/prepare":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/indexing\/prepare"}]}},"\/yoast\/v1\/indexing\/indexables-complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/indexing\/indexables-complete"}]}},"\/yoast\/v1\/indexing\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/indexing\/complete"}]}},"\/yoast\/v1\/link-indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/link-indexing\/posts"}]}},"\/yoast\/v1\/link-indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/link-indexing\/terms"}]}},"\/yoast\/v1\/integrations\/set_active":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"integration":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/integrations\/set_active"}]}},"\/yoast\/v1\/meta\/search":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/meta\/search"}]}},"\/yoast\/v1\/semrush\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/semrush\/authenticate"}]}},"\/yoast\/v1\/semrush\/country_code":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/semrush\/country_code"}]}},"\/yoast\/v1\/semrush\/related_keyphrases":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyphrase":{"required":true},"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/semrush\/related_keyphrases"}]}},"\/yoast\/v1\/workouts":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/workouts"}]}},"\/yoast\/v1\/complete_task":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"options":{"type":"object","properties":{"task":{"type":"string","required":true,"sanitize_callback":"sanitize_text_field"}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/complete_task"}]}},"\/yoast\/v1\/get_tasks":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"options":{"type":"object","properties":{"filter":{"type":"string","required":false,"sanitize_callback":"sanitize_text_field"},"limit":{"type":"int","required":false,"sanitize_callback":"absint"}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/get_tasks"}]}},"\/yoast\/v1\/action_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/yoast\/v1\/action_tracking"}]}},"\/elementor-one\/v1":{"namespace":"elementor-one\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor-one\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor-one\/v1"}]}},"\/elementor-one\/v1\/connect\/authorize":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"clearSession":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor-one\/v1\/connect\/authorize"}]}},"\/elementor-one\/v1\/connect\/disconnect":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor-one\/v1\/connect\/disconnect"}]}},"\/elementor-one\/v1\/connect\/switch-domain":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor-one\/v1\/connect\/switch-domain"}]}},"\/elementor-one\/v1\/connect\/deactivate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor-one\/v1\/connect\/deactivate"}]}},"\/elementor-one\/v1\/top-bar\/notifications":{"namespace":"elementor-one\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"app_name":{"type":"string","required":true},"app_version":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor-one\/v1\/top-bar\/notifications"}]}},"\/elementor-one\/v1\/top-bar\/feedback":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product":{"type":"string","required":true},"subject":{"type":"string","required":true},"title":{"type":"string","required":true},"description":{"type":"string","required":true},"countryCode":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor-one\/v1\/top-bar\/feedback"}]}},"\/elementor-one\/v1\/themes":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org theme directory slug.","pattern":"[\\w\\-]+","required":true},"status":{"description":"The theme activation status.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor-one\/v1\/themes"}]}},"\/elementor-one\/v1\/themes\/(?P<slug>[\\w\\-]+)\/activate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org theme directory slug.","pattern":"[\\w\\-]+","required":true}}}]},"\/elementor-one\/v1\/plugins":{"namespace":"elementor-one\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"status":{"description":"Beschr\u00e4nkt die Ergebnisse auf Plugins mit dem angegebenen Status.","type":"array","items":{"type":"string","enum":["inactive","active","network-active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true},"status":{"description":"The plugin activation status.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor-one\/v1\/plugins"}]}},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/activate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/deactivate":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/upgrade":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":["angie","manage","elementor","elementor-pro","site-mailer","image-optimization","pojo-accessibility"],"required":true},"status":{"description":"The plugin activation status.","type":"string","enum":["active"],"required":false}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/migration\/run":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":{"1":"manage","2":"elementor","3":"elementor-pro","4":"site-mailer","5":"image-optimization","6":"pojo-accessibility"},"required":true},"force":{"type":"boolean","default":true,"description":"Force migration even if the plugin is already connected.","required":false}}}]},"\/elementor-one\/v1\/plugins\/(?P<slug>[\\w\\-]+)\/migration\/rollback":{"namespace":"elementor-one\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org plugin directory slug.","enum":{"1":"manage","2":"elementor","3":"elementor-pro","4":"site-mailer","5":"image-optimization","6":"pojo-accessibility"},"required":true}}}]},"\/elementor-one\/v1\/settings":{"namespace":"elementor-one\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor-one\/v1\/settings"}]}},"\/zipwp\/v1":{"namespace":"zipwp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"zipwp\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1"}]}},"\/zipwp\/v1\/get-credits":{"namespace":"zipwp\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/get-credits"}]}},"\/zipwp\/v1\/zip-plan":{"namespace":"zipwp\/v1","methods":["POST","POST"],"endpoints":[{"methods":["POST"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/zip-plan"}]}},"\/zipwp\/v1\/revoke-access":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/revoke-access"}]}},"\/hfe\/v1":{"namespace":"hfe\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"hfe\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/hfe\/v1"}]}},"\/hfe\/v1\/widgets":{"namespace":"hfe\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/hfe\/v1\/widgets"}]}},"\/hfe\/v1\/plugins":{"namespace":"hfe\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/hfe\/v1\/plugins"}]}},"\/hfe\/v1\/templates":{"namespace":"hfe\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/hfe\/v1\/templates"}]}},"\/hfe\/v1\/email-webhook":{"namespace":"hfe\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/hfe\/v1\/email-webhook"}]}},"\/hfe\/v1\/recommended-plugins":{"namespace":"hfe\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/hfe\/v1\/recommended-plugins"}]}},"\/hfe\/v1\/get-learn-chapters":{"namespace":"hfe\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/hfe\/v1\/get-learn-chapters"}]}},"\/hfe\/v1\/update-learn-progress":{"namespace":"hfe\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"chapterId":{"type":"string","required":true},"stepId":{"type":"string","required":true},"completed":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/hfe\/v1\/update-learn-progress"}]}},"\/wpraddons\/v1\/ajaxselect2":{"namespace":"wpraddons\/v1\/ajaxselect2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpraddons\/v1\/ajaxselect2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wpraddons\/v1\/ajaxselect2"}]}},"\/wpraddons\/v1\/ajaxselect2\/(?P<action>\\w+)":{"namespace":"wpraddons\/v1\/ajaxselect2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/wpr-addons\/v1":{"namespace":"wpr-addons\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpr-addons\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wpr-addons\/v1"}]}},"\/wpr-addons\/v1\/widget-builder\/save\/(?P<id>[\\d]+)":{"namespace":"wpr-addons\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"required":false}}}]},"\/wpr-addons\/v1\/widget-builder\/save":{"namespace":"wpr-addons\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wpr-addons\/v1\/widget-builder\/save"}]}},"\/wpr-addons\/v1\/widget-builder\/load\/(?P<id>[\\d]+)":{"namespace":"wpr-addons\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false}}}]},"\/wpr-addons\/v1\/widget-builder\/delete\/(?P<id>[\\d]+)":{"namespace":"wpr-addons\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"id":{"required":false}}}]},"\/wpraddons\/v1":{"namespace":"wpraddons\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpraddons\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wpraddons\/v1"}]}},"\/wpraddons\/v1\/wprmegamenu":{"namespace":"wpraddons\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wpraddons\/v1\/wprmegamenu"}]}},"\/zipwp\/v1\/description":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_name":{"type":"string","required":true},"business_description":{"type":"string","required":false},"category":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/description"}]}},"\/zipwp\/v1\/images":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keywords":{"type":"string","required":true},"per_page":{"type":"string","required":false},"page":{"type":"string","required":false},"orientation":{"type":"string","required":false},"engine":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/images"}]}},"\/zipwp\/v1\/record-step":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action":{"type":"string","required":true},"current_step":{"type":"integer","required":true},"current_step_name":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/record-step"}]}},"\/zipwp\/v1\/keywords":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_name":{"type":"string","required":true},"business_description":{"type":"string","required":false},"category":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/keywords"}]}},"\/zipwp\/v1\/template-keywords":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_name":{"type":"string","required":true},"business_description":{"type":"string","required":false},"business_category":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/template-keywords"}]}},"\/zipwp\/v1\/categories":{"namespace":"zipwp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/categories"}]}},"\/zipwp\/v1\/site-features":{"namespace":"zipwp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/site-features"}]}},"\/zipwp\/v1\/site-languages":{"namespace":"zipwp\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/site-languages"}]}},"\/zipwp\/v1\/import-status":{"namespace":"zipwp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/import-status"}]}},"\/zipwp\/v1\/migration-status":{"namespace":"zipwp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/migration-status"}]}},"\/zipwp\/v1\/templates":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_name":{"type":"string","required":false},"keyword":{"type":"string","required":false},"page_builder":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/templates"}]}},"\/zipwp\/v1\/all-templates":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_name":{"type":"string","required":false},"per_page":{"type":"integer","required":false},"page":{"type":"integer","required":false},"page_builder":{"type":"string","required":false},"keyword":{"type":"string","required":false},"sort":{"type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/all-templates"}]}},"\/zipwp\/v1\/user-details":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_description":{"type":"string","required":true},"business_name":{"type":"string","required":true},"business_addeess":{"type":"string","required":false},"business_phone":{"type":"string","required":false},"business_email":{"type":"string","required":false},"social_profiles":{"type":"array","required":false},"business_category":{"type":"string","required":true},"site_language":{"type":"string","required":true},"keywords":{"type":"array","required":true},"images":{"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/user-details"}]}},"\/zipwp\/v1\/site":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"template":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/site"}]}},"\/zipwp\/v1\/wxr":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"template":{"type":"string","required":true},"business_name":{"type":"string","required":false},"business_description":{"type":"string","required":false},"language":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/wxr"}]}},"\/zipwp\/v1\/ai-site":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"template":{"type":"string","required":true},"business_name":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/ai-site"}]}},"\/zipwp\/v1\/search-category":{"namespace":"zipwp\/v1","methods":["POST","POST"],"endpoints":[{"methods":["POST"],"args":{"keyword":{"type":"string","required":true}}},{"methods":["POST"],"args":{"keyword":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/search-category"}]}},"\/zipwp\/v1\/import-error-log":{"namespace":"zipwp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/import-error-log"}]}},"\/zipwp\/v1\/set-step-data":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_details":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/set-step-data"}]}},"\/zipwp\/v1\/set-plan-promo-dismiss-time":{"namespace":"zipwp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/set-plan-promo-dismiss-time"}]}},"\/zipwp\/v1\/get-plan-promo-dismiss-time":{"namespace":"zipwp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp\/v1\/get-plan-promo-dismiss-time"}]}},"\/elementskit\/v1\/ajaxselect2":{"namespace":"elementskit\/v1\/ajaxselect2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementskit\/v1\/ajaxselect2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementskit\/v1\/ajaxselect2"}]}},"\/elementskit\/v1\/ajaxselect2\/(?P<action>\\w+)":{"namespace":"elementskit\/v1\/ajaxselect2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":[]}]},"\/astra\/v1":{"namespace":"astra\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"astra\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/astra\/v1"}]}},"\/astra\/v1\/admin\/settings":{"namespace":"astra\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/astra\/v1\/admin\/settings"}]}},"\/betterdocs":{"namespace":"betterdocs","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"betterdocs","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs"}]}},"\/betterdocs\/faq\/sample_data":{"namespace":"betterdocs","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/faq\/sample_data"}]}},"\/betterdocs\/faq\/posts\/(?P<type>\\S+)":{"namespace":"betterdocs","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/betterdocs\/faq\/create_category":{"namespace":"betterdocs","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/faq\/create_category"}]}},"\/betterdocs\/faq\/update_category":{"namespace":"betterdocs","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/faq\/update_category"}]}},"\/betterdocs\/faq\/delete_category":{"namespace":"betterdocs","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/faq\/delete_category"}]}},"\/betterdocs\/faq\/create_post":{"namespace":"betterdocs","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/faq\/create_post"}]}},"\/betterdocs\/faq\/update_post":{"namespace":"betterdocs","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/faq\/update_post"}]}},"\/betterdocs\/faq\/delete_post":{"namespace":"betterdocs","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/faq\/delete_post"}]}},"\/betterdocs\/faq\/category_status":{"namespace":"betterdocs","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/faq\/category_status"}]}},"\/betterdocs\/faq\/category_order":{"namespace":"betterdocs","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/faq\/category_order"}]}},"\/betterdocs\/faq\/update_order_by_category":{"namespace":"betterdocs","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/faq\/update_order_by_category"}]}},"\/betterdocs\/faq\/uncategorised":{"namespace":"betterdocs","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/faq\/uncategorised"}]}},"\/betterdocs\/faq\/category_search":{"namespace":"betterdocs","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"title":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/faq\/category_search"}]}},"\/betterdocs\/glossary\/sample_data":{"namespace":"betterdocs","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/glossary\/sample_data"}]}},"\/betterdocs\/glossary\/posts\/(?P<type>\\S+)":{"namespace":"betterdocs","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/betterdocs\/glossary\/create_glossary":{"namespace":"betterdocs","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/glossary\/create_glossary"}]}},"\/betterdocs\/glossary\/update_glossary":{"namespace":"betterdocs","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/glossary\/update_glossary"}]}},"\/betterdocs\/glossary\/delete_glossary":{"namespace":"betterdocs","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/glossary\/delete_glossary"}]}},"\/betterdocs\/glossary\/glossary_status":{"namespace":"betterdocs","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/glossary\/glossary_status"}]}},"\/betterdocs\/glossary\/glossaries_order":{"namespace":"betterdocs","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/glossary\/glossaries_order"}]}},"\/betterdocs\/glossary\/update_order_by_glossary":{"namespace":"betterdocs","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/glossary\/update_order_by_glossary"}]}},"\/betterdocs\/glossary\/glossary_search":{"namespace":"betterdocs","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"title":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/glossary\/glossary_search"}]}},"\/betterdocs\/glossary\/glossary_count":{"namespace":"betterdocs","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/glossary\/glossary_count"}]}},"\/betterdocs\/glossary\/get_glossaries":{"namespace":"betterdocs","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/betterdocs\/glossary\/get_glossaries"}]}},"\/elementor\/v1\/documents":{"namespace":"elementor\/v1\/documents","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1\/documents","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/documents"}]}},"\/elementor\/v1\/documents\/(?P<id>\\d+)\/media\/import":{"namespace":"elementor\/v1\/documents","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"required":true}}}]},"\/elementor\/v1":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1"}]}},"\/elementor\/v1\/cache":{"namespace":"elementor\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/cache"}]}},"\/elementor\/v1\/globals":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/globals"}]}},"\/elementor\/v1\/globals\/colors":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/globals\/colors"}]}},"\/elementor\/v1\/globals\/colors\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/globals\/typography":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/globals\/typography"}]}},"\/elementor\/v1\/globals\/typography\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/settings\/(?P<key>[\\w_-]+)":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/elementor\/v1\/post":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"included_types":{"description":"Included post types","type":"array","default":null,"required":false},"excluded_types":{"description":"Post type to exclude","type":"array","default":["e-floating-buttons","e-landing-page","elementor_library","attachment","revision","nav_menu_item","custom_css","customize_changeset"],"required":false},"term":{"description":"Posts to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":"array","default":{"ID":"id","post_title":"label","post_type":"groupLabel"},"required":false},"items_count":{"description":"Posts per page","type":"integer","default":100,"required":false},"is_public":{"description":"Whether to include only public post types","type":"boolean","default":true,"required":false},"meta_query":{"description":"WP_Query meta_query array","type":"array","default":null,"required":false},"tax_query":{"description":"WP_Query tax_query array","type":"array","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/post"}]}},"\/elementor\/v1\/term":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"included_types":{"description":"Included taxonomy containing terms (categories, tags, etc...)","type":"array","default":null,"required":false},"excluded_types":{"description":"Excluded taxonomy containing terms (categories, tags, etc...)","type":"array","default":null,"required":false},"term":{"description":"Terms to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":"array","default":{"term_id":"id","name":"label","taxonomy":"groupLabel"},"required":false},"items_count":{"description":"Terms per request","type":"integer","default":100,"required":false},"hide_empty":{"description":"Whether to include only public terms","type":"boolean","default":false,"required":false},"meta_query":{"description":"WP_Query meta_query array","type":"array","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/term"}]}},"\/elementor\/v1\/user":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"term":{"description":"Posts to search","type":"string","default":"","required":false},"keys_conversion_map":{"description":"Specify keys to extract and convert, i.e. [\"key_1\" => \"new_key_1\"].","type":["array","string"],"default":{"ID":"id","display_name":"label","role":"groupLabel"},"required":false},"items_count":{"description":"Posts per page","type":"integer","default":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/user"}]}},"\/elementor-ai\/v1":{"namespace":"elementor-ai\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor-ai\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor-ai\/v1"}]}},"\/elementor-ai\/v1\/permissions":{"namespace":"elementor-ai\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor-ai\/v1\/permissions"}]}},"\/elementor\/v1\/favorites":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/favorites"}]}},"\/elementor\/v1\/favorites\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Type of favorites.","type":"string","required":true},"favorite":{"description":"The favorite slug to create.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Type of favorites.","type":"string","required":true},"favorite":{"description":"The favorite slug to delete.","type":"string","required":true}}}]},"\/elementor\/v1\/kit-elements-defaults":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/kit-elements-defaults"}]}},"\/elementor\/v1\/kit-elements-defaults\/(?P<type>[\\w\\-\\_]+)":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"type":{"type":"string","description":"The type of the element.","required":true},"settings":{"description":"All the default values for the requested type","type":"object","required":true}}},{"methods":["DELETE"],"args":{"type":{"type":"string","description":"The type of the element.","required":true}}}]},"\/elementor\/v1\/site-navigation\/recent-posts":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"posts_per_page":{"description":"Number of posts to return","type":"integer","required":true},"post_type":{"description":"Post types to retrieve","type":"array","default":["page","post","elementor_library"],"required":false},"post__not_in":{"description":"Post id`s to exclude","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/site-navigation\/recent-posts"}]}},"\/elementor\/v1\/site-navigation\/add-new-post":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_type":{"description":"Post type to create","type":"string","default":"post","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/site-navigation\/add-new-post"}]}},"\/elementor\/v1\/checklist":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/checklist"}]}},"\/elementor\/v1\/checklist\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/checklist\/steps":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/checklist\/steps"}]}},"\/elementor\/v1\/checklist\/steps\/(?P<id>[\\d]+)":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/checklist\/steps\/(?P<id>[\\w\\-\\_]+)":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"type":"string","description":"The step id.","required":true}}}]},"\/elementor\/v1\/checklist\/user-progress":{"namespace":"elementor\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/checklist\/user-progress"}]}},"\/elementor\/v1\/components":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"status":{"type":"string","enum":["publish","draft","autosave"],"required":true},"items":{"type":"array","items":{"type":"object","properties":{"uid":{"type":"string","required":true},"title":{"type":"string","required":true,"minLength":2,"maxLength":200},"elements":{"type":"array","required":true,"items":{"type":"object"}},"settings":{"type":"object","required":false}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/components"}]}},"\/elementor\/v1\/components\/styles":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/components\/styles"}]}},"\/elementor\/v1\/components\/create-validate":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"items":{"type":"array","items":{"type":"object","properties":{"uid":{"type":"string","required":true},"title":{"type":"string","required":true,"minLength":2,"maxLength":200},"elements":{"type":"array","required":true,"items":{"type":"object"}},"settings":{"type":"object","required":false}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/components\/create-validate"}]}},"\/elementor\/v1\/components\/overridable-props":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"componentId":{"type":"integer","description":"The component ID to get overridable props for","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/components\/overridable-props"}]}},"\/elementor\/v1\/components\/status":{"namespace":"elementor\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":{"status":{"type":"string","enum":["publish"],"required":true},"ids":{"type":"array","items":{"type":"number","required":true},"required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/components\/status"}]}},"\/elementor\/v1\/components\/lock":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"componentId":{"type":"number","description":"The component ID to unlock","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/components\/lock"}]}},"\/elementor\/v1\/components\/unlock":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"componentId":{"type":"number","description":"The component ID to unlock","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/components\/unlock"}]}},"\/elementor\/v1\/components\/lock-status":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"componentId":{"type":"string","description":"The component ID to check lock status","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/components\/lock-status"}]}},"\/elementor\/v1\/components\/archive":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"componentIds":{"type":"array","items":{"type":"number","required":true},"description":"The component IDs to archive","required":true},"status":{"type":"string","enum":["publish","draft","autosave"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/components\/archive"}]}},"\/elementor\/v1\/components\/update-titles":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"components":{"type":"array","items":{"type":"object","properties":{"componentId":{"type":"number","required":true,"description":"The component ID to update title"},"title":{"type":"string","required":true,"description":"The new title for the component"}}},"required":true},"status":{"type":"string","enum":["publish","draft","autosave"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/components\/update-titles"}]}},"\/elementor\/v1\/feedback":{"namespace":"elementor\/v1\/feedback","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1\/feedback","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/feedback"}]}},"\/elementor\/v1\/feedback\/submit":{"namespace":"elementor\/v1\/feedback","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/feedback\/submit"}]}},"\/elementor\/v1\/template-library\/templates":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"title":{"type":"string","description":"The title of the document","required":false},"type":{"description":"The document type.","type":"string","enum":["page","section","container"],"required":true},"content":{"description":"Elementor data object","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/template-library\/templates"}]}},"\/elementor\/v1\/user-data\/current-user":{"namespace":"elementor\/v1","methods":["GET","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["PATCH"],"args":{"suppressedMessages":{"type":"array","description":"Array of suppressed message keys","items":{"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/user-data\/current-user"}]}},"\/elementskit\/v1\/widget\/mailchimp":{"namespace":"elementskit\/v1\/widget\/mailchimp","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementskit\/v1\/widget\/mailchimp","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementskit\/v1\/widget\/mailchimp"}]}},"\/elementskit\/v1\/widget\/mailchimp\/(?P<action>\\w+)":{"namespace":"elementskit\/v1\/widget\/mailchimp","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":[]}]},"\/elementskit\/v1\/dynamic-content":{"namespace":"elementskit\/v1\/dynamic-content","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementskit\/v1\/dynamic-content","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementskit\/v1\/dynamic-content"}]}},"\/elementskit\/v1\/dynamic-content\/(?P<action>\\w+)\/(?P<type>\\w+)\/(?P<key>\\w+(|[-]\\w+))":{"namespace":"elementskit\/v1\/dynamic-content","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":[]}]},"\/elementskit\/v1\/layout-manager-api":{"namespace":"elementskit\/v1\/layout-manager-api","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementskit\/v1\/layout-manager-api","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementskit\/v1\/layout-manager-api"}]}},"\/elementskit\/v1\/layout-manager-api\/(?P<action>\\w+)":{"namespace":"elementskit\/v1\/layout-manager-api","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":[]}]},"\/elementskit\/v1\/my-template":{"namespace":"elementskit\/v1\/my-template","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementskit\/v1\/my-template","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementskit\/v1\/my-template"}]}},"\/elementskit\/v1\/my-template\/(?P<action>\\w+)\/(?P<id>\\w+)":{"namespace":"elementskit\/v1\/my-template","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":[]}]},"\/elementskit\/v1\/megamenu":{"namespace":"elementskit\/v1\/megamenu","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementskit\/v1\/megamenu","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementskit\/v1\/megamenu"}]}},"\/elementskit\/v1\/megamenu\/(?P<action>\\w+)":{"namespace":"elementskit\/v1\/megamenu","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":[]}]},"\/one-onboarding\/v1":{"namespace":"one-onboarding\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"one-onboarding\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/one-onboarding\/v1"}]}},"\/one-onboarding\/v1\/plugin-status\/(?P<plugin>[a-zA-Z0-9_-]+)":{"namespace":"one-onboarding\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/one-onboarding\/v1\/install-plugin":{"namespace":"one-onboarding\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/one-onboarding\/v1\/install-plugin"}]}},"\/one-onboarding\/v1\/activate-plugin":{"namespace":"one-onboarding\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/one-onboarding\/v1\/activate-plugin"}]}},"\/one-onboarding\/v1\/save-onboarding-state":{"namespace":"one-onboarding\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/one-onboarding\/v1\/save-onboarding-state"}]}},"\/one-onboarding\/v1\/onboarding-completion":{"namespace":"one-onboarding\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/one-onboarding\/v1\/onboarding-completion"}]}},"\/getting-started\/v1":{"namespace":"getting-started\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"getting-started\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/getting-started\/v1"}]}},"\/getting-started\/v1\/action-items":{"namespace":"getting-started\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/getting-started\/v1\/action-items"}]}},"\/getting-started\/v1\/dismiss-setup-wizard":{"namespace":"getting-started\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"dismiss":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/getting-started\/v1\/dismiss-setup-wizard"}]}},"\/getting-started\/v1\/update-action-item-steps":{"namespace":"getting-started\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action_id":{"type":"string","required":true},"steps":{"type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/getting-started\/v1\/update-action-item-steps"}]}},"\/zipwp-images\/v1":{"namespace":"zipwp-images\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"zipwp-images\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp-images\/v1"}]}},"\/zipwp-images\/v1\/images":{"namespace":"zipwp-images\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keywords":{"type":"string","required":true},"per_page":{"type":"string","required":false},"page":{"type":"string","required":false},"orientation":{"type":"string","required":false},"engine":{"type":"string","required":false},"filter":{"type":"string","required":false},"color":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/zipwp-images\/v1\/images"}]}},"\/nps-survey\/v1":{"namespace":"nps-survey\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"nps-survey\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/nps-survey\/v1"}]}},"\/nps-survey\/v1\/rating":{"namespace":"nps-survey\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"nps_id":{"type":"string","required":true},"rating":{"type":"integer","required":true},"comment":{"type":"string","default":"","required":false},"plugin_slug":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/nps-survey\/v1\/rating"}]}},"\/nps-survey\/v1\/dismiss-nps-survey":{"namespace":"nps-survey\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"nps_id":{"type":"string","required":true},"plugin_slug":{"type":"string","required":true},"dismiss_timespan":{"type":"integer","required":true},"current_step":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/nps-survey\/v1\/dismiss-nps-survey"}]}},"\/gutenberg-templates\/v1":{"namespace":"gutenberg-templates\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"gutenberg-templates\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/gutenberg-templates\/v1"}]}},"\/gutenberg-templates\/v1\/categories":{"namespace":"gutenberg-templates\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/gutenberg-templates\/v1\/categories"}]}},"\/gutenberg-templates\/v1\/description":{"namespace":"gutenberg-templates\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_name":{"type":"string","required":true},"business_description":{"type":"string","required":false},"category":{"type":"string","required":false},"language_name":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/gutenberg-templates\/v1\/description"}]}},"\/gutenberg-templates\/v1\/page-description":{"namespace":"gutenberg-templates\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_name":{"type":"string","required":true},"business_description":{"type":"string","required":false},"page_name":{"type":"string","required":true},"page_description":{"type":"string","required":false},"category":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/gutenberg-templates\/v1\/page-description"}]}},"\/gutenberg-templates\/v1\/keywords":{"namespace":"gutenberg-templates\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_name":{"type":"string","required":true},"business_description":{"type":"string","required":false},"category":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/gutenberg-templates\/v1\/keywords"}]}},"\/gutenberg-templates\/v1\/images":{"namespace":"gutenberg-templates\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keywords":{"type":"string","required":true},"per_page":{"type":"integer","required":false},"page":{"type":"integer","required":false},"orientation":{"type":"string","required":false},"engine":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/gutenberg-templates\/v1\/images"}]}},"\/gutenberg-templates\/v1\/settings":{"namespace":"gutenberg-templates\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"key":{"type":"string","required":true},"value":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/gutenberg-templates\/v1\/settings"}]}},"\/gutenberg-templates\/v1\/favorite":{"namespace":"gutenberg-templates\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"type":{"type":"string","required":true},"block_id":{"type":"integer","required":true},"status":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/gutenberg-templates\/v1\/favorite"}]}},"\/gutenberg-templates\/v1\/do-it-later":{"namespace":"gutenberg-templates\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/gutenberg-templates\/v1\/do-it-later"}]}},"\/gutenberg-templates\/v1\/pages-onboarding":{"namespace":"gutenberg-templates\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/gutenberg-templates\/v1\/pages-onboarding"}]}},"\/gutenberg-templates\/v1\/revoke-access":{"namespace":"gutenberg-templates\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/gutenberg-templates\/v1\/revoke-access"}]}},"\/gutenberg-templates\/v1\/blocks":{"namespace":"gutenberg-templates\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/gutenberg-templates\/v1\/blocks"}]}},"\/gutenberg-templates\/v1\/setup":{"namespace":"gutenberg-templates\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/gutenberg-templates\/v1\/setup"}]}},"\/gutenberg-templates\/v1\/sites":{"namespace":"gutenberg-templates\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/gutenberg-templates\/v1\/sites"}]}},"\/bsf-core\/v1":{"namespace":"bsf-core\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"bsf-core\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/bsf-core\/v1"}]}},"\/bsf-core\/v1\/license\/activate":{"namespace":"bsf-core\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"product-id":{"type":"string","required":true},"license-key":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/bsf-core\/v1\/license\/activate"}]}},"\/elementor\/v1\/library\/connect":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"token":{"type":"string","description":"Connect CLI token","required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/library\/connect"}]}},"\/elementor\/v1\/send-event":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false}}},{"methods":["POST"],"args":{"event_data":{"description":"All the recorded event data in JSON format","type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/elementor\/v1\/send-event"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie categories zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den aufgelisteten IDs abgleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriffs-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, miteinbezogen werden sollen.","type":"boolean","default":false},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie categories zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den aufgelisteten IDs abgleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriffs-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, miteinbezogen werden sollen.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie tags zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den aufgelisteten IDs abgleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriffs-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie tags zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den aufgelisteten IDs abgleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriffs-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Den Ergebnissatz auf Elemente begrenzen, die oben gehalten werden.","type":"boolean","required":false},"ignore_sticky":{"description":"Ob oben gehaltene Beitr\u00e4ge ignoriert werden sollen oder nicht.","type":"boolean","default":true,"required":false},"format":{"description":"Den Ergebnissatz auf Elemente begrenzen, denen ein oder mehrere bestimmte Formate zugeordnet sind.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"fifu_image_url":{"type":"string","title":"","description":"","default":""},"fifu_image_alt":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","wpr-theme-builder","wpr-popups","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","elementor_component",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"fifu_image_url":{"type":"string","title":"","description":"","default":""},"fifu_image_alt":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","wpr-theme-builder","wpr-popups","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","elementor_component",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"fifu_image_url":{"type":"string","title":"","description":"","default":""},"fifu_image_alt":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","wpr-theme-builder","wpr-popups","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","elementor_component",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die einen bestimmten menu_order-Wert haben.","type":"integer","required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Den Ergebnissatz auf alle Elemente bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Den Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen mit einer bestimmten \u00fcbergeordneten ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","wpr-theme-builder","wpr-popups","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","elementor_component",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","wpr-theme-builder","wpr-popups","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","elementor_component",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","wpr-theme-builder","wpr-popups","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","elementor_component",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Den Ergebnissatz auf alle Elemente bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Den Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen mit einer bestimmten \u00fcbergeordneten ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Den Ergebnissatz auf Anh\u00e4nge eines bestimmten Medientyps oder bestimmter Medientypen begrenzen.","type":"array","items":{"type":"string","enum":["image","video","audio","text","application"]},"required":false},"mime_type":{"default":null,"description":"Den Ergebnissatz auf Anh\u00e4nge eines bestimmten MIME-Typs oder bestimmter MIME-Typen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"alt_text":{"description":"Alternativtext, der angezeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false},"caption":{"description":"Die Beschriftung des Anhangs.","type":"object","properties":{"raw":{"description":"Die Beschriftung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Die f\u00fcr die Anzeige umgewandelte HTML-Beschriftung des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"alt_text":{"description":"Alternativtext, der angezeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false},"caption":{"description":"Die Beschriftung des Anhangs.","type":"object","properties":{"raw":{"description":"Die Beschriftung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Die f\u00fcr die Anzeige umgewandelte HTML-Beschriftung des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Anhang.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL zur bearbeiteten Bilddatei.","type":"string","format":"uri","required":true},"modifiers":{"description":"Array an Bildbearbeitungen.","type":"array","minItems":1,"items":{"description":"Bildbearbeitung.","type":"object","required":["type","args"],"oneOf":[{"title":"Spiegeln","properties":{"type":{"description":"Die Art der Spiegelung.","type":"string","enum":["flip"]},"args":{"description":"Die Spiegelungs-Argumente.","type":"object","required":["flip"],"properties":{"flip":{"description":"Die Richtung der Spiegelung.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Ob in horizontaler Richtung gespiegelt werden soll.","type":"boolean"},"vertical":{"description":"Ob in vertikaler Richtung gespiegelt werden soll.","type":"boolean"}}}}}}},{"title":"Rotation","properties":{"type":{"description":"Rotations-Typ.","type":"string","enum":["rotate"]},"args":{"description":"Rotations-Argumente.","type":"object","required":["angle"],"properties":{"angle":{"description":"Winkel in Grad f\u00fcr die Rotation im Uhrzeigersinn.","type":"number"}}}}},{"title":"Zuschneiden","properties":{"type":{"description":"Typ des Zuschnitts.","type":"string","enum":["crop"]},"args":{"description":"Zuschnitt-Argumente.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Horizontale Position von links, an der der Zuschnitt beginnen soll, in Prozent der Bildbreite.","type":"number"},"top":{"description":"Vertikale Position von oben, an der der Zuschnitt beginnen soll, in Prozent der Bildh\u00f6he.","type":"number"},"width":{"description":"Die Breite des Zuschnitts in Prozent der Bildbreite.","type":"number"},"height":{"description":"Die H\u00f6he des Zuschnitts in Prozent der Bildh\u00f6he.","type":"number"}}}}}]},"required":false},"rotation":{"description":"Der Winkel in Grad, um den das Bild im Uhrzeigersinn gedreht werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"Die x-Position des Bildes in Prozent, an der das Zuschneiden des Bildes beginnen soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"Die y-Position des Bildes in Prozent, an der das Zuschneiden des Bildes beginnen soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"Die Breite des Bildes in Prozent, auf die das Bild zugeschnitten werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"Die H\u00f6he des Bildes in Prozent, auf die das Bild zugeschnitten werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"Die Beschriftung des Anhangs.","type":"object","properties":{"raw":{"description":"Die Beschriftung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Die f\u00fcr die Anzeige umgewandelte HTML-Beschriftung des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer","required":false},"alt_text":{"description":"Alternativtext, der angezeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie menus zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den aufgelisteten IDs abgleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriffs-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie menus zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den aufgelisteten IDs abgleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriffs-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die einen bestimmten menu_order-Wert haben.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"default":0,"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Linkelements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Linkelement dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"default":1,"description":"Die DB-ID des nav_menu_item, das gegebenenfalls der \u00fcbergeordnete Men\u00fceintrag dieses Elements ist; andernfalls 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"default":0,"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Linkelements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Linkelements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Linkelement dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"description":"Die DB-ID des nav_menu_item, das gegebenenfalls der \u00fcbergeordnete Men\u00fceintrag dieses Elements ist; andernfalls 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Linkelements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Linkelements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Linkelement dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"description":"Die DB-ID des nav_menu_item, das gegebenenfalls der \u00fcbergeordnete Men\u00fceintrag dieses Elements ist; andernfalls 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Linkelements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie wp_pattern_category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den aufgelisteten IDs abgleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriffs-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie wp_pattern_category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den aufgelisteten IDs abgleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriffs-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Auf die angegebene Beitrags-ID begrenzen.","type":"integer","required":false},"area":{"description":"Auf den angegebenen Bereich des Template-Teils begrenzen.","type":"string","required":false},"post_type":{"description":"Inhaltstyp f\u00fcr die Templates.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"default":"","description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Beschreibung des Templates.","type":"string","required":false},"status":{"default":"publish","description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Die Titelform des Templates, f\u00fcr das das Fallback abgerufen werden soll","type":"string","required":true},"is_custom":{"description":"Gibt an, ob ein Template individuell oder Teil der Template-Hierarchie ist","type":"boolean","required":false},"template_prefix":{"description":"Das Template-Pr\u00e4fix f\u00fcr das erstellte Template. Dies wird verwendet, um den Haupt-Template-Typ zu extrahieren, z.\u00a0B. in `taxonomy-books` wird die `taxonomy` extrahiert","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Auf die angegebene Beitrags-ID begrenzen.","type":"integer","required":false},"area":{"description":"Auf den angegebenen Bereich des Template-Teils begrenzen.","type":"string","required":false},"post_type":{"description":"Inhaltstyp f\u00fcr die Templates.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"default":"","description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Beschreibung des Templates.","type":"string","required":false},"status":{"default":"publish","description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Die Titelform des Templates, f\u00fcr das das Fallback abgerufen werden soll","type":"string","required":true},"is_custom":{"description":"Gibt an, ob ein Template individuell oder Teil der Template-Hierarchie ist","type":"boolean","required":false},"template_prefix":{"description":"Das Template-Pr\u00e4fix f\u00fcr das erstellte Template. Dies wird verwendet, um den Haupt-Template-Typ zu extrahieren, z.\u00a0B. in `taxonomy-books` wird die `taxonomy` extrahiert","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision f\u00fcr globale Stile.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung der Revision f\u00fcr globale Stile.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Die Theme-Kennung","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Die Theme-Kennung","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"Die ID der Konfiguration f\u00fcr globale Stile.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Globale Stile.","type":["object"],"required":false},"settings":{"description":"Globale Einstellungen.","type":["object"],"required":false},"title":{"description":"Der Titel der globalen Stilvariante.","type":["object","string"],"properties":{"raw":{"description":"Der Titel der globalen Stilvariante, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Schriftfamilien-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Schriftfamilien-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"Schriftschnitt-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"id":{"description":"Eindeutige Kennung f\u00fcr den Schriftschnitt.","type":"integer","required":true},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"id":{"description":"Eindeutige Kennung f\u00fcr den Schriftschnitt.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/e-floating-buttons":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die einen bestimmten menu_order-Wert haben.","type":"integer","required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"format":{"description":"Den Ergebnissatz auf Elemente begrenzen, denen ein oder mehrere bestimmte Formate zugeordnet sind.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","wpr-theme-builder","wpr-popups","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","elementor_component",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/e-floating-buttons"}]}},"\/wp\/v2\/e-floating-buttons\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","wpr-theme-builder","wpr-popups","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","elementor_component",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/e-floating-buttons\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/e-floating-buttons\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/e-floating-buttons\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","wpr-theme-builder","wpr-popups","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","elementor_component",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/e-floating-buttons\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/elementor_library":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","wpr-theme-builder","wpr-popups","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","elementor_component",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/elementor_library"}]}},"\/wp\/v2\/elementor_library\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","wpr-theme-builder","wpr-popups","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","elementor_component",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/elementor_library\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/elementor_library\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/elementskit-content":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Den Ergebnissatz auf alle Elemente bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Den Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen mit einer bestimmten \u00fcbergeordneten ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","wpr-theme-builder","wpr-popups","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","elementor_component",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/elementskit-content"}]}},"\/wp\/v2\/elementskit-content\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","wpr-theme-builder","wpr-popups","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","elementor_component",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/elementskit-content\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/elementskit-content\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/elementskit-content\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","wpr-theme-builder","wpr-popups","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","elementor_component",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/elementskit-content\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/elementskit-template":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","wpr-theme-builder","wpr-popups","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","elementor_component",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/elementskit-template"}]}},"\/wp\/v2\/elementskit-template\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"_elementor_edit_mode":{"type":"string","title":"Elementor edit mode","description":"Elementor edit mode, `builder` is required for Elementor editing","default":"","enum":["","builder"],"context":["edit"]},"_elementor_template_type":{"type":"string","title":"Elementor template type","description":"Elementor document type","default":"","enum":["post","wp-post","wp-page","wpr-theme-builder","wpr-popups","kit","not-supported","page","section","container","floating-buttons","cloud-template-preview","elementor_component",""],"context":["edit"]},"_elementor_data":{"type":"string","title":"Elementor data","description":"Elementor JSON as a string","default":"","context":["edit"]},"_elementor_page_settings":{"type":"object","title":"Elementor page settings","description":"Elementor page level settings","default":"{}","properties":{"hide_title":{"type":"string","enum":["yes","no"],"default":""}},"additionalProperties":true,"context":["edit"]}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/elementskit-template\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/elementskit-template\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/docs":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"doc_category":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie doc_category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den aufgelisteten IDs abgleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriffs-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, miteinbezogen werden sollen.","type":"boolean","default":false},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"doc_category_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie doc_category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den aufgelisteten IDs abgleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriffs-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, miteinbezogen werden sollen.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"doc_tag":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie doc_tag zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den aufgelisteten IDs abgleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriffs-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, miteinbezogen werden sollen.","type":"boolean","default":false},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"doc_tag_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie doc_tag zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den aufgelisteten IDs abgleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriffs-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, miteinbezogen werden sollen.","type":"boolean","default":false}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"doc_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie doc_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"doc_tag":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie doc_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"year_month":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"word_count":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"total_views":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"reactions":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"author_info":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"doc_category_info":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"doc_tag_info":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/docs"}]}},"\/wp\/v2\/docs\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"doc_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie doc_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"doc_tag":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie doc_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"year_month":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"word_count":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"total_views":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"reactions":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"author_info":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"doc_category_info":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"doc_tag_info":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/docs\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/docs\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/docs\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"doc_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie doc_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"doc_tag":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie doc_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"year_month":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"word_count":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"total_views":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"reactions":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"author_info":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"doc_category_info":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"doc_tag_info":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false}}}]},"\/wp\/v2\/docs\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/betterdocs_faq":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Den Ergebnissatz auf alle Elemente bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Den Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen mit einer bestimmten \u00fcbergeordneten ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"betterdocs_faq_category":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie betterdocs_faq_category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den aufgelisteten IDs abgleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriffs-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, miteinbezogen werden sollen.","type":"boolean","default":false},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"betterdocs_faq_category_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie betterdocs_faq_category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den aufgelisteten IDs abgleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriffs-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, miteinbezogen werden sollen.","type":"boolean","default":false}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"faq_open_by_default":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"betterdocs_faq_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie betterdocs_faq_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/betterdocs_faq"}]}},"\/wp\/v2\/betterdocs_faq\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"faq_open_by_default":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"betterdocs_faq_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie betterdocs_faq_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/betterdocs_faq\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/betterdocs_faq\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/betterdocs_faq\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":""},"ast-site-content-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-style":{"type":"string","title":"","description":"","default":"default"},"site-sidebar-style":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-banner-title-visibility":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"astra-migrate-meta-layouts":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-enabled":{"type":"string","title":"","description":"","default":"default"},"ast-page-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-5)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"ast-content-background-meta":{"type":"object","title":"","description":"","default":{"desktop":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"tablet":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""},"mobile":{"background-color":"var(--ast-global-color-4)","background-image":"","background-repeat":"repeat","background-position":"center center","background-size":"auto","background-attachment":"scroll","background-type":"","background-media":"","overlay-type":"","overlay-color":"","overlay-opacity":"","overlay-gradient":""}},"properties":{"desktop":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"tablet":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false},"mobile":{"type":"object","properties":{"background-color":{"type":"string"},"background-image":{"type":"string"},"background-repeat":{"type":"string"},"background-position":{"type":"string"},"background-size":{"type":"string"},"background-attachment":{"type":"string"},"background-type":{"type":"string"},"background-media":{"type":"string"},"overlay-type":{"type":"string"},"overlay-color":{"type":"string"},"overlay-opacity":{"type":"string"},"overlay-gradient":{"type":"string"}},"additionalProperties":false}},"additionalProperties":false},"faq_open_by_default":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"betterdocs_faq_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie betterdocs_faq_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/betterdocs_faq\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Elements der automatischen Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Eine alphanumerische Kennung f\u00fcr den Inhaltstyp.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Eine alphanumerische Kennung f\u00fcr den Status.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Ergebnisse auf Taxonomien begrenzen, die einem bestimmten Inhaltstyp zugeordnet sind.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Eine alphanumerische Kennung f\u00fcr die Taxonomie.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"parent":{"description":"Den Ergebnissatz auf Begriffe begrenzen, die einem bestimmten \u00fcbergeordneten Objekt zugewiesen sind.","type":"integer","required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false},"locations":{"description":"Die dem Men\u00fc zugeordneten Positionen.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ob Seiten der obersten Ebene automatisch zu diesem Men\u00fc hinzugef\u00fcgt werden sollen.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false},"locations":{"description":"Die dem Men\u00fc zugeordneten Positionen.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ob Seiten der obersten Ebene automatisch zu diesem Men\u00fc hinzugef\u00fcgt werden sollen.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/doc_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count","doc_category_order"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"parent":{"description":"Den Ergebnissatz auf Begriffe begrenzen, die einem bestimmten \u00fcbergeordneten Objekt zugewiesen sind.","type":"integer","required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false},"doc_category_order":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"thumbnail":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"handbookthumbnail":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"subcategories_count":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"total_docs_count":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"last_updated_time":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/doc_category"}]}},"\/wp\/v2\/doc_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false},"doc_category_order":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"thumbnail":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"handbookthumbnail":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"subcategories_count":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"total_docs_count":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false},"last_updated_time":{"description":"Holds the thumbnail URL of doc category","type":"string","format":"url","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/doc_tag":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"parent":{"description":"Den Ergebnissatz auf Begriffe begrenzen, die einem bestimmten \u00fcbergeordneten Objekt zugewiesen sind.","type":"integer","required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/doc_tag"}]}},"\/wp\/v2\/doc_tag\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/betterdocs_faq_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"parent":{"description":"Den Ergebnissatz auf Begriffe begrenzen, die einem bestimmten \u00fcbergeordneten Objekt zugewiesen sind.","type":"integer","required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"order":{"type":"array","items":{"type":"string","title":"","description":"","default":""}},"status":{"type":"array","items":{"type":"string","title":"","description":"","default":""}},"_betterdocs_faq_order":{"type":"array","items":{"type":"string","title":"","description":"","default":""}},"faq_group_icon":{"type":"array","items":{"type":"string","title":"","description":"","default":""}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/betterdocs_faq_category"}]}},"\/wp\/v2\/betterdocs_faq_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"order":{"type":"array","items":{"type":"string","title":"","description":"","default":""}},"status":{"type":"array","items":{"type":"string","title":"","description":"","default":""}},"_betterdocs_faq_order":{"type":"array","items":{"type":"string","title":"","description":"","default":""}},"faq_group_icon":{"type":"array","items":{"type":"string","title":"","description":"","default":""}}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"default":"asc","description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sammlung nach Benutzerattribut sortieren.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Ergebnissatz auf Benutzer mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Ergebnissatz auf Benutzer begrenzen, die mindestens einer bestimmten Rolle entsprechen. Akzeptiert eine CSV-Liste oder eine einzelne Rolle.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Den Ergebnissatz auf Benutzer begrenzen, die mindestens eine bestimmte angegebene Berechtigung haben. Akzeptiert werden eine CSV-Liste oder eine einzelne Berechtigung.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Ergebnissatz auf Benutzer begrenzen, die als Autoren gelten.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Den Ergebnissatz auf Benutzer begrenzen, die Beitr\u00e4ge ver\u00f6ffentlicht haben.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","e-floating-buttons":"e-floating-buttons","elementor_library":"elementor_library","elementskit_content":"elementskit_content","elementskit_template":"elementskit_template","docs":"docs","betterdocs_faq":"betterdocs_faq"}},"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":true},"name":{"description":"Der Anzeigename f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":true},"url":{"description":"Die URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Die Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Die Lokalisierung des Benutzers.","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","hi_IN","id_ID","ja","pl_PL","pt_PT","ru_RU","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":true},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Voreinstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":false},"name":{"description":"Der Anzeigename f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":false},"url":{"description":"Die URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Die Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Die Lokalisierung des Benutzers.","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","hi_IN","id_ID","ja","pl_PL","pt_PT","ru_RU","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Voreinstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Benutzer k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false},"reassign":{"type":"integer","description":"Die Beitr\u00e4ge und Links des gel\u00f6schten Benutzers dieser Benutzer-ID neu zuweisen.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":false},"name":{"description":"Der Anzeigename f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":false},"url":{"description":"Die URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Die Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Die Lokalisierung des Benutzers.","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","hi_IN","id_ID","ja","pl_PL","pt_PT","ru_RU","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Voreinstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"elementor_introduction":{"description":"Elementor user meta data","type":"object","properties":{"ai_get_started":{"type":"boolean"}},"additionalProperties":true,"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Benutzer k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false},"reassign":{"type":"integer","description":"Die Beitr\u00e4ge und Links des gel\u00f6schten Benutzers dieser Benutzer-ID neu zuweisen.","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Eine UUID, die von der Anwendung bereitgestellt wird, um sie eindeutig zu identifizieren. Es wird empfohlen, eine UUID\u00a0v5 mit dem URL- oder DNS-Namensraum zu verwenden.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Der Name des Anwendungspassworts.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Eine UUID, die von der Anwendung bereitgestellt wird, um sie eindeutig zu identifizieren. Es wird empfohlen, eine UUID\u00a0v5 mit dem URL- oder DNS-Namensraum zu verwenden.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Der Name des Anwendungspassworts.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Kommentare einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Kommentare begrenzen, denen bestimmte Benutzer-IDs zugewiesen sind. Erfordert eine Autorisierung.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Kommentare ausschlie\u00dft, die bestimmten Benutzer-IDs zugewiesen sind. Erfordert eine Autorisierung.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Den Ergebnissatz auf den einer speziellen E-Mail-Adresse eines Autors begrenzen. Erfordert eine Autorisierung.","format":"email","type":"string","required":false},"before":{"description":"Antwort auf Kommentare einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Kommentarattribut sortieren.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Den Ergebnissatz auf Kommentare bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Sicherstellen, dass der Ergebnissatz bestimmte \u00fcbergeordnete IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Ergebnissatz auf Kommentare begrenzen, die bestimmten Beitrags-IDs zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Ergebnissatz auf Kommentare begrenzen, denen ein bestimmter Status zugewiesen ist. Erfordert eine Autorisierung.","type":"string","required":false},"type":{"default":"comment","description":"Ergebnissatz auf Kommentare begrenzen, denen ein bestimmter Typ zugewiesen ist. Erfordert eine Autorisierung.","type":"string","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"Die ID des Benutzerobjekts, falls der Autor ein Benutzer war.","type":"integer","required":false},"author_email":{"description":"E-Mail-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"email","required":false},"author_ip":{"description":"IP-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"ip","required":false},"author_name":{"description":"Der Anzeigename f\u00fcr den Kommentarautor.","type":"string","required":false},"author_url":{"description":"URL f\u00fcr den Autor des Kommentars.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User Agent f\u00fcr den Autor des Kommentars.","type":"string","required":false},"content":{"description":"Der Inhalt f\u00fcr den Kommentar.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Kommentar, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Kommentar, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Kommentar ver\u00f6ffentlicht wurde.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"Die ID f\u00fcr den \u00fcbergeordneten Kommentar.","type":"integer","required":false},"post":{"default":0,"description":"Die ID des zugeordneten Beitragsobjekts.","type":"integer","required":false},"status":{"description":"Status des Kommentars.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status der Anmerkung","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den \u00fcbergeordneten Beitrag des Kommentars (wenn der Beitrag passwortgesch\u00fctzt ist).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"author":{"description":"Die ID des Benutzerobjekts, falls der Autor ein Benutzer war.","type":"integer","required":false},"author_email":{"description":"E-Mail-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"email","required":false},"author_ip":{"description":"IP-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"ip","required":false},"author_name":{"description":"Der Anzeigename f\u00fcr den Kommentarautor.","type":"string","required":false},"author_url":{"description":"URL f\u00fcr den Autor des Kommentars.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User Agent f\u00fcr den Autor des Kommentars.","type":"string","required":false},"content":{"description":"Der Inhalt f\u00fcr den Kommentar.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Kommentar, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Kommentar, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Kommentar ver\u00f6ffentlicht wurde.","type":"string","format":"date-time","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Kommentar.","type":"integer","required":false},"post":{"description":"Die ID des zugeordneten Beitragsobjekts.","type":"integer","required":false},"status":{"description":"Status des Kommentars.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status der Anmerkung","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false},"password":{"description":"Das Passwort f\u00fcr den \u00fcbergeordneten Beitrag des Kommentars (wenn der Beitrag passwortgesch\u00fctzt ist).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"type":{"default":"post","description":"Ergebnisse auf Elemente eines Objekt-Typs beschr\u00e4nken.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Ergebnisse auf Elemente eines oder mehrerer Objekt-Subtypen einschr\u00e4nken.","type":"array","items":{"enum":["post","page","e-floating-buttons","elementor_library","elementskit_content","elementskit_template","docs","category","post_tag","doc_category","doc_tag","any"],"type":"string"},"required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Eindeutiger registrierter Name f\u00fcr den Block.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Attribute f\u00fcr den Block.","type":"object","default":[],"required":false},"post_id":{"description":"Die ID des Beitragskontextes.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Blockname.","type":"string","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"title":{"title":"Titel","description":"Website-Titel.","type":"string","required":false},"description":{"title":"Untertitel","description":"Website-Untertitel.","type":"string","required":false},"timezone":{"title":"","description":"Eine Stadt in deiner Zeitzone.","type":"string","required":false},"date_format":{"title":"","description":"Ein Datumsformat f\u00fcr alle datumsbasierten Zeichenfolgen.","type":"string","required":false},"time_format":{"title":"","description":"Ein Zeitformat f\u00fcr alle zeitbasierten Zeichenfolgen.","type":"string","required":false},"start_of_week":{"title":"","description":"Die Zahl eines Wochentages, mit dem die Woche beginnen sollte.","type":"integer","required":false},"language":{"title":"","description":"Der WordPress-Lokalisierungscode.","type":"string","required":false},"use_smilies":{"title":"","description":"Emoticons wie :-) und :-P als Grafiken anzeigen.","type":"boolean","required":false},"default_category":{"title":"","description":"Standard-Beitragskategorie.","type":"integer","required":false},"default_post_format":{"title":"","description":"Standard-Beitragsformat.","type":"string","required":false},"posts_per_page":{"title":"Maximale Beitragsanzahl pro Seite","description":"Maximal angezeigte Beitr\u00e4ge.","type":"integer","required":false},"show_on_front":{"title":"Vorne anzeigen","description":"Was auf der Homepage angezeigt werden soll","type":"string","required":false},"page_on_front":{"title":"Titelseite","description":"Die ID der Seite, die auf der Homepage angezeigt werden soll","type":"integer","required":false},"page_for_posts":{"title":"","description":"Die ID der Seite, auf der die neuesten Beitr\u00e4ge angezeigt werden sollen","type":"integer","required":false},"default_ping_status":{"title":"","description":"Link-Benachrichtigungen von anderen Blogs (Pingbacks und Trackbacks) zu neuen Beitr\u00e4gen erlauben.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Kommentare bei neuen Beitr\u00e4gen erlauben","description":"Erlaubt Personen, neue Beitr\u00e4ge zu kommentieren.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Website-Logo.","type":"integer","required":false},"site_icon":{"title":"Icon","description":"Website-Icon.","type":"integer","required":false},"elementor_one_welcome_screen_completed":{"title":"","description":"Elementor One Welcome Screen Completed","type":"boolean","required":false},"elementor_one_dismiss_connect_alert":{"title":"","description":"Elementor One Dismiss Connect Alert","type":"boolean","required":false},"elementor_one_editor_update_notification_dismissed":{"title":"","description":"Elementor One Dismiss Editor Update Notification","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Ergebnissatz auf Themes begrenzen, die einem oder mehreren Status zugewiesen sind.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"Das Stylesheet des Themes. Dieses identifiziert das Theme eindeutig.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"status":{"description":"Beschr\u00e4nkt die Ergebnisse auf Plugins mit dem angegebenen Status.","type":"array","items":{"type":"string","enum":["inactive","active","network-active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Titelform im WordPress.org-Plugin-Verzeichnis.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Der Aktivierungsstatus des Plugins.","type":"string","enum":["inactive","active","network-active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"Der Aktivierungsstatus des Plugins.","type":"string","enum":["inactive","active","network-active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID einer registrierten Seitenleiste","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Verschachtelte Widgets.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":true},"instance":{"description":"Aktuelle Instanz-Einstellungen des Widgets.","type":"object","required":false},"form_data":{"description":"Serialisierte Widget-Formulardaten zur Kodierung in Instanz-Einstellungen.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":true},"instance":{"description":"Aktuelle Instanz-Einstellungen des Widgets.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"Die Seitenleiste, f\u00fcr die Widgets zur\u00fcckgegeben werden sollen.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr das Widget.","type":"string","required":false},"id_base":{"description":"Typ des Widgets. Entspricht der ID im Endpunkt widget-types.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"Die Seitenleiste, zu der das Widget geh\u00f6rt.","type":"string","required":true},"instance":{"description":"Instanz-Einstellungen des Widgets, falls unterst\u00fctzt.","type":"object","properties":{"encoded":{"description":"Base64-kodierte Darstellung der Instanz-Einstellungen.","type":"string","context":["edit"]},"hash":{"description":"Kryptographischer Hash der Instanz-Einstellungen.","type":"string","context":["edit"]},"raw":{"description":"Nicht kodierte Instanz-Einstellungen, falls unterst\u00fctzt.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-kodierte Formulardaten aus dem Widget-Adminformular. Werden verwendet, um ein Widget zu aktualisieren, das keine Instanz unterst\u00fctzt. Nur Schreibzugriff.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr das Widget.","type":"string","required":false},"id_base":{"description":"Typ des Widgets. Entspricht der ID im Endpunkt widget-types.","type":"string","required":false},"sidebar":{"description":"Die Seitenleiste, zu der das Widget geh\u00f6rt.","type":"string","required":false},"instance":{"description":"Instanz-Einstellungen des Widgets, falls unterst\u00fctzt.","type":"object","properties":{"encoded":{"description":"Base64-kodierte Darstellung der Instanz-Einstellungen.","type":"string","context":["edit"]},"hash":{"description":"Kryptographischer Hash der Instanz-Einstellungen.","type":"string","context":["edit"]},"raw":{"description":"Nicht kodierte Instanz-Einstellungen, falls unterst\u00fctzt.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-kodierte Formulardaten aus dem Widget-Adminformular. Werden verwendet, um ein Widget zu aktualisieren, das keine Instanz unterst\u00fctzt. Nur Schreibzugriff.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Ob das Entfernen des Widgets erzwungen werden soll oder ob es in die inaktive Seitenleiste verschoben werden soll.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Ergebnissatz auf Bl\u00f6cke beschr\u00e4nken, die mit dem Suchbegriff \u00fcbereinstimmen.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","minLength":1,"required":false},"category":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Kategorie-ID \u00fcbereinstimmen.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Stichwort-ID \u00fcbereinstimmen.","type":"integer","minimum":1,"required":false},"slug":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Vorlage (Titelform) \u00fcbereinstimmen.","type":"array","required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Zu verarbeitende URL.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Eine alphanumerische Kennung f\u00fcr die Men\u00fcposition.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Eine eindeutige Kennung f\u00fcr die F\u00e4higkeitskategorie.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Eindeutige Kennung f\u00fcr die F\u00e4higkeit.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Eingabeparameter f\u00fcr die Ausf\u00fchrung der F\u00e4higkeit.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Die Ergebnisse auf F\u00e4higkeiten einer bestimmten F\u00e4higkeitskategorie begrenzen.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Eindeutige Kennung f\u00fcr die F\u00e4higkeit.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]}},"site_logo":1199,"site_icon":1204,"site_icon_url":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-content\/uploads\/sites\/5\/2026\/01\/cropped-tree-diagram-favicon.png","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_logo","href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/media\/1199"},{"embeddable":true,"type":"site_icon","href":"https:\/\/tree-diagram-maker.visual-paradigm.com\/de\/wp-json\/wp\/v2\/media\/1204"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
