Lotus Blossom Technique
The Lotus Blossom Technique is a structured brainstorming method that helps you explore a central topic in great depth. You start with your main idea in the center, surround it with eight related concepts, and then use each of those concepts as the center of a new blossom. This blueprint creates the perfect visual structure to facilitate this expansive thinking process.
tick-icon (3)
Structured 8-Node Blossoms: The perfect structure for exploring your central theme and its related sub-themes.
tick-icon (3)
AI Theme Expansion: Provide your central topic, and the AI can generate the first eight related themes to get you started.
tick-icon (3)
Deep Brainstorming: Use “Generate Children” on any of the eight themes to flesh out the outer petals of the blossom.
tick-icon (3)
AI Insight for Connections: The AI can analyze your completed blossom to find surprising connections between different themes.
Lotus Blossom Technique example
