Leveraging AI for Speed and Creativity #
Our AI features are designed to be your creative partner, helping you brainstorm, structure, and analyze your diagrams with minimal effort. Each Blueprint has a specially-tuned AI that acts as an expert in that field (e.g., a project manager for WBS, a strategist for SWOT).
Generate a Full Diagram from a Topic #
This is the best way to start a new project from a blank slate. It’s incredibly powerful for brainstorming and initial drafting.
- In the “Editor” tab, find the “Generate with AI” section.
- Enter a topic for your diagram. Tip: The more specific your prompt, the better the result. Instead of “Marketing,” try “A marketing plan for a new vegan cafe in Brooklyn.”
- Click the “Generate” button. The AI will create a complete, multi-level diagram tailored to your chosen blueprint and topic.
Generate Children to Expand an Idea #
This “bottom-up” feature is perfect for fleshing out an existing structure. It helps you think through all the necessary details.
- In the visual diagram, click on the text label of the node you want to expand.
- At the bottom of the “Editor” tab, the “Generate Children” button will become active.
- Click it. The AI analyzes the selected node and its parents to understand the context, then generates a list of relevant sub-points. For example, selecting a WBS task called “Conduct User Testing” might generate children like “Recruit test participants,” “Write test script,” and “Analyze results.”
Get High-Level AI Insight #
This is the most powerful analysis feature. Once your diagram has a good amount of detail, the AI can act as a consultant.
- Navigate to the “AI Insight” tab in the left panel.
- Click the “Generate Insight” button.
- The AI will analyze your entire diagram and its properties. It will provide a written report that might include:
- For a WBS: Potential risks, scheduling conflicts, or unassigned critical tasks.
- For a SWOT: Strategic recommendations based on how your strengths can counter threats.
- For a Mind Map: Key themes, underdeveloped areas, and surprising connections.
This transforms your diagram from a static document into a source of strategic advice.
